classiccat
- Joined
- Dec 20, 2010
- 3,412
Have you cleaned (sanded) the terminals (battery to solenoid stud, solenoid to starter)? Also, what gauge cable are you running for those connections and how long are the runs (hopefully the cranking battery is under the splashwell and not the center console)? How old is the cranking battery and how many CCA's is it rated for?found the first issue, a broken splice from one of the power cables from the ignition (probably bad work by myself).
Now that that’s fixed, looks like the solenoid is the culprit, it clicks but it’s only putting out 6.5 volts to the starter.
