harringtondav
Thread starter- Joined
- May 26, 2018
- 2,528
Simple, inexpensive maintenance can save you a lot of headaches.
Yesterday I noticed the new heat pump split system at our river house wasn't keeping up. It was running on back up electric heat strip. I checked the power going to the heat strip and found it was only drawing 1/2 current. Momentary panic. Then I remembered that I'd been generating a lot of drywall dust from a basement finish project. New filter and all was well. The clogged filter forced the heat strip into low power mode to avoid burning up. So check and replace your furnace filters often. Filters are cheap.
