ShoestringMariner
- Joined
- Apr 18, 2015
- 1,605
Thanks. I only paid at the bottom at this time. I didn’t want to get into extending the painting process at all. I figured that if I still have time left before the spring opener I’ll paint the top side while it’s on the trailer. If not I’ll leave it for next winter. The lake opens may 1st and I still have so much to do. My work week is long and I’m often burnt out weeknights so not much work happens until the weekend.That's awesome! We're in opposite order, with my foam and floor just completed, working on side panels next. If there's time, maybe I should flip it over again, and paint rather than leave bare with sharkhide. How much primer/paint was needed for that bottom section? Did you prime the whole hull, and just tape off and finish paint the bottom? I need to go back and check your earlier posts....
For quantities, I ended up using a quart and a half for the bottom. 1/2 quart per coat for primer. Probably a 1/4 to 3rd quart per coat on the bottom topcoat due to thinner viscosity. There’s 4 white coats on it to make the colour consistent. Do you guys think that’s enough for build?
