AKJohne
Thread starter- Joined
- Mar 26, 2017
- 220
1997 5.7 LX Alpha 1 Gen 2
Looking for advice on connecting power to a electric fuel pump.
I am in the process of replacing the old motor with a new long block. Bought the motor and electric fuel pump "kit" from Michigan Motorz which included a NC oil pressure switch. The wiring diagram MM supplied and the wiring diagram I have found here for a carbed Mercs electric fuel pump show the power for the fuel pump coming from
the starter (purple/yellow). However my starter does not have a third lug, only the post for B+ and the yellow/red from the ignition switch to the solenoid.
My plan is to install the oil pressure switch in tandem with the oil pressure sender on the back of the motor (not the alarm switch location) and connect to the purple wire from the ignition that connects to the coil/ dist/alternator.
Does this make sense? Is there something I am missing/overlooking?
Thanks.
Thanks.
