johncapecod
Thread starter- Joined
- Oct 30, 2002
- 6
My 30 year old Yamaha 115 two stroke has one cylinder that doesn’t fire. If I pull that spark plug wire nothing changes but there is plenty of spark. The compression is 120/120/120/100. The carburetors have been cleaned and rebuilt and in the Venturi valves nothing seemed amiss. I switched the coils and the same cylinder has the problem. The motor dies if rev’d above 2000 RPM. I don’t see any oil leaks under the cowling. I got rid of the precision blend system and went with a premix because the oil pump was no longer available for this motor when this issue started. I guess what I’m wondering is if I should spend any more time on this motor (parts are no longer being produced)? There are a lit of these motors out there but the YouTube videos I’ve seen don’t address this particular problem. Hopefully, this forum will offer some guidance. Thanks for reading.
