- Joined
- Jul 23, 2011
- 52,313
with spark plugs out, dizzy out, crank engine with your finger over the spark plug hole for #1.
stop cranking when the air pushes your finger out of the hole
on the exhaust stroke, you will get a little pfft
on the compression stroke you will get PPPPPPPFFFFFFFFTTTTTTTT
now rotate the motor CW or CCW as needed the smidge to get the balancer and timing marks to align
now grab the dizzy off the bench, rotate the shaft as needed to align with #1 tower, and turn it about 30 degrees...... and here is why. the gears are a helix, as you install the distributor, the rotor will turn about 30 degrees.
the distributor is now aligned roughly with #1 tower, however still has not engaged the oil pump tang yet. the dizzy will also be sitting about 1/4" up from the top of the manifold boss.
crank the motor until the dizzy drops into the oil pump shaft.
now, bring the motor back around to #1 TDC on the compression stroke. this is to verify that you are still pointing to #1 spark plug tower on the cap.
install the dizzy hold-down, however to not fully tighten, you must be able to grab the dizzy to turn slightly to set timing
now install the cap, wires, plugs
crank the motor and set timing. (motor doesnt even need fuel as you should be able to set timing while cranking)
