- Joined
- Mar 8, 2009
- 44,687
So I obviously have the newer one that doesn't have any resistor in-line.. Does this mean I have the wrong cable, or do I just need to add an external yellow cap resistor to my junction box, do you think?
Ahhh no, and sort of
Using pic in post 14, there are 2 types and yours is the one on top with a resistor built into each end of the cable. It shows no resistor is needed with the J box and only using weather caps
The another one has only one resistor built into the cable so that end is marked so it will only be installed in one location. And one resistor is used on one connection of the J box.
All this said, the pic showing the weather caps also was for another manual discussing installing a Tach and Speedometer.
