2003 Mercury 200 2 Stroke carb running hot at idle. New impeller, new thermostats
When on the muffs with motor stopped the impeller itself BLOCKS the flow of water to the engine.
diver94
Yes, but that doesn't happens when the hose is connected to the flushing port/on top. Maybe the thermostats do stop the flow of water(because they stay closed under 143 degrees)
