ShoestringMariner
Thread starter- Joined
- Apr 18, 2015
- 1,605
I’m using a Noco genesis onboard dual bank charger for the 2 trolling motor batteries.you never mentioned how you will charge these batteries. on a old mopar you could run a 10ga wire fused on BOTH ends 50amp fuse and go alt <> batt+.
dunno how that applies to you.
myself im gonna use a solar controller and panel to recharge.
there are wire size charts online. like your trollingmotor called for 8ga, because its going to use 30amps or whatever the spec is.
you can calculate all these things for the loads you will run - radio, troller, lights, etc.
The starter battery will be charged by the alternator And I will likely hook that one up to A small solar panel while I am away to keep the battery topped in case the auto bilge pump cycles a few times. The bilge pump will be the only thing that does not go through the kill switch.
The reason I’m considering using this “mini add a battery“ switch system is because I don’t have shore power at the dock. So my electric charger is only used when I bring the boat home for early/late season boating elsewhere. During the summer season at my trailer, I’m hoping that the motor alternator can help keep both the motor battery level and the house battery level up when running. There are also entire weekends where I like to get out camping off the grid. I have to rely on whatever charge I brought with me or alternator power when running.
In any case, this system has a relay that allows the engine to charge both batteries but when the engine is off only the house battery is drawn off of by electronics etc. I know I can do this with a few disconnect switches in the circuit but this will allow a lot less for fooling around or forgetting switches on/off.
here’s a link to the video. https://www.bluesea.com/resources/533/Add-A-Battery_Video
