Jeffress77
Thread starter- Joined
- May 27, 2011
- 26
Hello all,
I just upgraded my setup by purchasing a used 70 hp 2002/2003 Nissan NSD70A2.
Says on tag it was manufactured March 2002 but apparently they only made this model number in 2003?? Not sure there… doesn’t make much of a difference, but I would like some advice:
This engine has been stored for 3 years. I have only owned older Johnson/Evinride engines and this is a different breed, so I would like to know all the steps you guys think I should take to properly prepare the outboard for startup. I want to make sure I cover all the necessary steps to ensure filters/hoses/electrical/lubrication is correct before I start it up for the first time in 3 years (from what I was told).
I want to change the impeller/associated water pump parts, any necessary filters, plugs, wires, lower unit oil, motor injection oil, etc… anything else?
Thanks so much in advance!
I have plenty more questions we can get to after you read all I have bombarded you with already!
- Justin
- Justin
