Hello, I am having an issue with the warning module. I bought a boat with this outboard about 2 years ago now and ever since I have had it, the warning buzzer has been on as soon as i turn the ignition switch on. A mechanic checked it out after I purchased it and said the buzzer itself was bad. I bought a new one and replaced it(connects to the ignition switch) and it's still on, constantly, never turns off. I found a service manual for the outboard online and got to troubleshooting. Ended up believing it was the temp sensor. So i bought a new one for about 100 bucks, connected it and the buzzer is still on. It turns off as soon as i disconnect the black wire, which i am assuming is ground(manual says if it turns off after disconnecting the black wire, it is a bad temp sensor but i just put a brand new temp sensor in and haven't used the boat since swapping the temp sensor??) I went a step further, disconnected the two blue wires from the warning module, re connected the black wire and the buzzer came back on. I am not sure if the warning module itself and wouldn't know how to test it.
The serial number to the outboard is: 0D121478
And the service manual can be found here:
drive.google.com
The section containing information regarding the warning module can be found on page 124 w/ the wiring diagrams being on 124. Mine is the model without the test button. Perhaps, I'm not reading the manual correctly, but I am not sure what to do here.
Thanks for any information you can provide.
Mariner 90 Service Manual.pdf
