Carburetor Fuel Filter
88 Capri (2022 SOTY)
I have a curiosity question. I had bought a rebuilt carburetor when I was working on getting the engine running couple of years ago when I first acquired the boat but what in the world would cause this?
I am rebuilding the original so I am not immediately needing this one but I have never seen this.
I purchased the bronze filters for the other one but still want an idea lol
Grub54891
Either someone installed it wrong, or put the spring in wrong or it’s to long or….?
I know originally there should be a spring, but there wasn't one in this carburetor and wouldn't have been enough room anyway. I only thought of a rebuild on this because the engine wouldn't idle at 650 (closest I could get was 900 rpm) and had an irradic drip at idle. I'm hopeful that my rebuild of the old one will get me to the rpm I need for shifting.
I'm working on locating a spring for the bronze filter, but I don't know the dimensions of it, so more investigation is needed.
Grub54891
I might be able to measure one tomorrow at work, I’ll try to make time to check. Regardless, it’s not a mercruiser specific part. Most any parts store should be able to set you up. Just bring them the serial number on the carb body.
Ayuh,.... I believe the filters come in two lengths, 'n the last guy Mashed a long one, in a short hole,....
I'd think you can get a filter, 'n spring at Napa,....
j cat
Thanks for both of your inputs 😊.
I do not like those plastic gas carb filters.my 1978 carb filter is s/steel fuel screen...fuel pump is a fiber filter 3inches X 1/5 inches on the fuel pump..
I remove the gasoline when I store it in the fall.. no muck ... fuel looks good.. fuel additive all the time...
That filter was installed by a company that I bought the carburetor from, and I agree with you on not liking them. I just rebuilt my spare carburetor, it has the bronze filter with a spring inside it. My filter is much smaller than the one you have being a 2bbl for a 4 cylinder.
I also have the fuel water seperator.
