Bell housing spacers Alpha 1 Gen 2
Superjetjim
Hi, does anyone know where I can get a couple of these spacers? Assume they sell them as a separate part? E51A74F7-5551-4A19-B2D9-605DD350AEB6.jpeg533B5218-84A9-436D-91C3-FB491988B931.jpeg
Bt Doctur
the spacers for the rear mounts do not have brass bushings.
a better description of the part is needed and where its needed
achris
More fish than mountain goat
When referring to stern drive power packages, 'bell housing' is the part attached to the gimbal ring that the drive bolts up to. I think you are referring to the 'flywheel housing' on the back of the engine. And as such that spacer is part of the rear engine mount attaching hardware. And it's not available separately, you need to buy a full 'bolt kit', as Bondo had said...
Chris...
Superjetjim
The full bolt kit is $26 x 2 - I’ll have proper dig around and find the originals for that price!
Thanks
achris
Managed to find an old reference. Try Merc part -99799...
Chris....
Rick Stephens
If someone walked into my shop and asked for a couple, I would grab up a piece of thick walled alum tuning with a 1/2 inch hole and toss in a saw. 5 minutes max. Surely there is a small welding business nearby.
Superjetjim
Thanks chaps, I got an endoscope camera and found them behind the motor. All installed now.
