Thermostat
brian3127
Finishing up putting the engine back together.
Serial number 4920382
What temp thermostat is recommended
Fun Times
Most likely a 140 or 143 degree temp…
In your case though the serial number isn’t enough to help locate your exact engine model due to the age of the serial number/engine year while performing a full computer search.
To help local your engine parts, we’d/you’ll need the engine model type, year, HP and serial number too to get a better idea of what parts to use on your exact Mercruiser set-up.
achris
More fish than mountain goat
It's a 1978 140hp...
j cat
your engine is on my mercrusier manual 143F ....many mercrusier Engines open cooling .. Serial number 4920382 ...... engines use the same T stat ..
my 470 engine has a closed cooling system 160F T stat.
brian3127
Mercruiser 3.0 140hp
j cat
your serial # is on my OEM mercrusier manual Engine Serial number 4920382..
point gap .022 dwell 31-34 deg spark plug ac-mr43-t or champion rbl-8 gap .035 idle rpm 650-700 timing 6deg BTDC at idle ..................oil 4qts .
your carb should be 2GC # 7043/7044 [182/184]
carb float level 5/8in float drop 1-7/8in idle mixture setting 1-1/4 turn
brian3127
I don’t have points
It was changed over before I bought it
Thanks for the info
achris
Electronic ignition
Yes, I got that. I'm asking to ensure it's SAE-J1701 rated.
What sort of 'electronic'? The complete distributor, or something like a Pertronic points eliminator?
Chris.....
j cat
I don’t have points
Thanks for the info
I did the change on the up date of ignition points, I install a electronic ignition pertronix 1146a . probably 25 yrs ago .
my engine increases higher power . less gasoline ..
brian3127
Chris.....
good question. there is an ignition module on the distributor looks just like a car setup. I don't know what the numbers are on it. The boat is still in it's winter cocoon.
j cat
your 140hp merc 1978 yr the distributor is a pertronix 1146A ..electronic ignition conversion kit ..to change the points.
https://www.go2marine.com/Electronic-Ignition-Conversion-Kit-Delco-4-Cyl-1146A ... I did not change the ignition coil . see if the distributor cap removes it and look up the pertronix ignitor ..may change the points..
achris
If the distributor has a module on the outside (as stated by the owner) then it's not a Pertronic unit, it's something different, and probably not marine...
Chris....
brian3127
brian3127
Chris....
If this isn't the correct one should I order a Pertronic unit
achris
Pertronic is just a points elimination module, not a complete distributor. Looking at that picture, it's difficult to really pin down...
Chris...
brian3127
Chris...
i forgot I had a close up pic of it on my phone
