Evinrude 28 special water pump
Jordandh198826
Good evening everyone. I have just completed replacing the entire waterpump in my 1995 28 special, and when all is said and done, I have 2 rubber o rings left over. I've carefully inspected everything I removed and there were no o rings present. Does anyone have any idea what these could be for?
Part # of the kit you used ?---Pictures ?------Is there a plastic tube stuck up above the pump?-----The 2 identical o-rings might fit on that part.
Jordandh198826
It is a glm marine part number 12060.
Is there a plastic tube stuck in the exhaust housing , yes or no, or no idea what to look for ?----This tube fits in the top of the water pump and is about 3" long !
Jordandh198826
No, there is no exhaust housing tube on the water pump on this model
Jordandh198826
This is the water pump in it's entirety. The "tube" I was referring to is the water tube. I was half asleep when you mentioned the other tube and didn't grip what you said lol
The parts book shows a spacer ( item 68 ) above the pump.-------I can not see your motor , or know what has been done.-----Perhaps the spacer is only used on long shaft models.-----The kit comes with o-rings for it..-----So perhaps throw them out.----Sorry.
Jordandh198826
Do you happen to have a picture? There is a spacer that mounts above the lower unit on this model.
I know motors.-----Don't know pictures.-----Easy for you to look at your motor or the online parts books !
