grease not going in gimbal
kingsfisherman
trying to grease the gimbal and it's coming out by the hole, did I miss it or maybe the band spun around?
BRICH1260
Did you spin the bearing as you pumped in the grease. Is it possible that it is full? By the pic, I would guess that your passage into the bearing are not aligned. Are you sure that the bearing even is greaseable. The newer ones are "maintenance free" and are not greaseable.
kingsfisherman
thanks Brich for your reply, it is greaseable and I will pull it out and replace to try again
thank you alldodge for your reply, same old boat new greaseable bearing,. gonna pull and replace
Ayuh,...... Before ya do that, that's the outer race, that gimbals,.....
Yer gonna need to realign after, but wobble the outer race around,......
Ya might get Lucky, 'n it'll take the grease,.....
'n I agree on rotatin' the bearing as ya grease it,....
Idlin' on the muffs, it's easy peasy,....
