Clarko1988
Thread starter- Joined
- Apr 27, 2021
- 103
Can it leak in just one cylinder?Look at the manifolds
@Scott Danforth is referring to the exhaust manifolds, and yes....Can it leak in just one cylinder?
Ayuh,..... If the manifold/ riser joint gasket fails, in leaks into the downhill cylinder,......Can it leak in just one cylinder?
engine over heats and many have the head gasket damage ... looks like engine water ports dirty ..Took heads off to check gaskets and for cracks cant seem to find anything this motor was rebuilt last summer including heads i overheated once and instantly shut the motor down.
Ive check head gasket and didint see any thing no cracked nothingengine over heats and many have the head gasket damage ... looks like engine water ports dirty ..
I agree. For the photos it looks more like an exhaust manifold water intrusion... Seen it many many times unfortunately..Ive check head gasket and didint see any thing no cracked nothing
I made a mistake it is cylinder 6 that has the waterNot sure this is my problem but how would i find out if this is cracked? There was no water in the other cylinder just number 5.
Had the heads tested and the checked out fine. Did the head gaskets today. Still trying to figure it out. Is it possible that intake manifold leaks just in cylinder 5?#6 is the rear one on the starboard (drivers) side.
do you have wet joint or dry joint exhaust?
if wet joint what do the sealing surfaces of the manifolds/elbows look like?
salt or fresh water?
the best thing to do would have been to air pressure test the cooling system passages before removing the cyl heads.
that and taking the manifolds & elbows apart, and propping up the manifolds level and filling (careful flammable) with acetone. Acetone has less surface tension than water and will find leaks in a manifold that won't show with water till it warms up
when I had water in a cyl I first tested my old manifolds (both passed) then rigged up a way to test the head gaskets with the engine running. What I found was that exhaust gas was getting in to the cooling water. That confirmed either a blown HG or cracked head. Dis-assembly revealed both.
But I ruled out the manifolds first.
Where u are at now, you can:
test the manifolds
take the heads off to get magnafluxed and gone over at a machine shop
check the deck of the block very carefully
report back what you find.
Even less than half, is around 12 lb/ft iirc. With a proper sequence and multiple passes with slightly increasing torque. Also, even though not recommended I use a gasket sealant around the water passages on both the heads and intake manifold....The torque spec for the Vortec is like 1/2 of the Pre Vortec. If the mechanic is not aware of this you will have leaks. On the Pre Vortec the intake gaskets rarely if ever leak.....
