- Joined
- Jul 23, 2011
- 52,802
the 1996 and later 4.3's have 5 drain plugs. 2 block, 2 exhaust manifold, 1 in the thermostat housing on the intake manifold. that one gets missedWhich drain is this?
Going to try and check the oil today when I get home. Does the dipstick tube run to the bottom of the sump? Or close enough to see the water if I vacuum it out of the dipstick?If there is water behind the timing cover, there is water in the pan.
Might pull a breather tube off a valve cover and see if there is white foamy stuff on the underside. Note that the dipstick will not see water - oil floats and water is at bottom, so when you pull the dipstick it will look clean. Only good way to know if there is water is to drain the oil or use a vacuum to pull some off the bottom of the pan.
Yeah, we've had this discussion before. It isn't necessary to drain, none of the service manuals (that I can find) mention it, that space is cavernous and drains (almost?) completely when you pull the t stat hose. Someone prove me wrong (@Scott Danforth )this one....
the Pre-Vortec engines did not have this, I'm not sure what they changed to make that a necessity on the Vortec...
I've pulled that plug a few times now, always bone dry. And even if there was water in there, there's plenty of expansion room. You got a copy of that bulletin?I recall our discussion, yep, the only thing I can say is that I found an OMC Cobra service bulletin that said that under certain conditions freeze damage can occur if you don't drain it. Having never had one, I can't say and for sure on the older pre Vortecs as soon as you pull the bottom of big hose on the circulating pump the whole thing drains. Not sure what they changed, that could make a difference.
forums.iboats.com
Not going to prove you wrong, because you are not. I will share an experiment I performed several years ago.Yeah, we've had this discussion before. It isn't necessary to drain, none of the service manuals (that I can find) mention it, that space is cavernous and drains (almost?) completely when you pull the t stat hose. Someone prove me wrong (@Scott Danforth )
I can prove you right.Yeah, we've had this discussion before. It isn't necessary to drain, none of the service manuals (that I can find) mention it, that space is cavernous and drains (almost?) completely when you pull the t stat hose. Someone prove me wrong (@Scott Danforth )
