Trike rider
Thread starter- Joined
- Aug 13, 2020
- 10
Checking the trim motor and found the motor has three wires one is the ground. Found that the motor runs constantly and there is power at the ground
It's a mercruiser 5.7 sterndrive. It will work if you put power to the up or down wiresChecking the trim motor and found the motor has three wires one is the ground. Found that the motor runs constantly and there is power at the ground
relays are a coil wound contactor that is used for switching powerA 3 wire PTT motor will use solenoids instead of relays. These solenoids work the same a starter solenoids, that is, when energized, they supply power to one winding, and leave the other winding open.
Relays ground the winding, when not energized, which is bad for 3 wire PTT motor windings.
So check to make sure that you have solenoids, and that power only goes to one of them at a time, when the trim buttons are pushed. Also make sure the black wire is well grounded.
Sometimes when PTT motors are replaced, 2 wire PTT motors replace 3 wire PTT motors, and the solenoids are replaced with relays. That means that both types of motors could be available. Maybe the PO replaced a 2 wire PTT motor with a 3 wire PTT motor, and left the relays wired in?
