2010 bayliner 2009 motor
Bayliner12345
Change oil and put new battery womt turn over please help just got this boat and its been sitting for a year worked last time we took it out .
Grub54891
Pretty common to miss a wire when replacing a battery, check for anything you may have missed. Also make sure you didn't hook it up backwards. Make sure all the connections are shiny clean. Get a voltmeter and chech for power at the wiring leading from the wire to the helm, and grounds at the block. Thats just a start if it still doesn't work, let us know. If it does let us know. Welcome to I-boats!
Welcome aboard
Does it crank and not fire, or not turn over?
Did you clean the battery cables and connections?
I/O or OB?
If I/O, how did you winterize?
Bayliner12345
My brother did hook up one wire backwards but corrected it. The engine was seized up a little bit but we got it loose. The starter acts like it's engaging but it still won't turn the motor over.
Grub54891
Remove the sparkplugs, see if it cranks. Also squirt a tad of oil in the plug holes. By the way, what motor? And a little history of how it was stored and serviced in the past. Was it winterized before storage?
what motor
its never good if a motor is seized up.....ever
how did you winterize it?
JimS123
If you hooked up the battery backwards, you probably blew a fuse and that's why it won't work. Seized is yet another problem.
QBhoy
Think you need to take the plugs out, if all electrical things seem good.
