Jonboat_0908
Thread starter- Joined
- Apr 16, 2022
- 6
I have a 1989 25 hp evinrude water still not coming out the tell tail. I’ve replace the water pump and the thermostat already. I notice when I shot water threw the bottom of the water pipe it eventually flows threw and out the tell tail. But when I shine my light up inside the house as I’m shooting water threw the water pipe most of the water is dumping out inside above where the water pipe slide in. I’ve replaced both the gromets the water pipe slides into and made sure the rubber grommets are in place correctly. Is there another gasket above all that inside the housing? What else would cause no water to come out the tell tail? I’ve read several other threads similar to my problem and no luck. Thanks
