Dirtymike20
- Joined
- Aug 9, 2021
- 33
I've done some research.. but multiple threads on the subject. I live in nebraska and my boat is just under a carport.
After draining the motor.. fill a drum with rv antifreeze and run a hose with muffs till red comes out of the exhaust.. then should I drain the antifreeze? Or leave the engine full.
My engine block drain ports have hoses that lead to a lower hose. Alot of the hoses lead to this plastic dome with a plug. I know it drains most of the water but I'm very certain not all water is leaving the engine.. but main question.. do I leave the AF in the motor? Or should I drain after flush.
Any tips or tricks?
It's a multi port 5.0 merccruiser bravo 3.
Like I said I have a plug at the top by the thermostat I think.. one on the front that most of the hoses run to. And also two on the water pump I believe. Its on the right side of the engine, two plugs vertical of each other 3 inches apart.
Any tips or tricks?
