Telltale and electronic ignition started in ‘77 on those motors. Reed spacers and tuned exhaust tube for 15hp came later, both were in place in ‘81
Marketing 101-----Put a 9.9 HP decal on a motor that produces 11.6 HP.------Put a 15 HP decal on a motor that produces 13.9 HP on the dyno.-----May not be exact numbers but you get the idea.
Reed spacers and tuners were more mid 80s items.
NO Do not stick a clothes hanger up there to try to open it. Will do more damage than good. If you want to replace it pull the powerhead and replace it.Thanks guys. Did a little more research.
Leroy mentions in 81 the 15 got the round exhaust. And the 9.9 finally got it in 90.
I can totally relate. I never noticed a huge difference between the 9.9 and the 15's. Other than noise (high rev) and bit more torque under heavy load. Noticeable, but not huge.
Thanks . Leroy also mentions the shims came in 79 too .
Just picked her up . Can confirm there is a tell tale. CDI . Haven't opened her up yet to check any internals. But am expecting to find a square exhaust and no spacers. I'll replace the impeller with a kit, plugs, and drop the carb into an ultrasonic bath, and see what else needs to be done.
Would you recommend sticking a straightened coat hanger on the end up a drill and widening the water inlet grommet at the head while I have her open. I've heard disaster stories of the grommet collapsing and plugging up not allowing water to circulate.
yesJust picked up a 1976 15HP parts motor
Looks complete.
I want to swap carbs.
Will the 76 15hp carb fit in a 77 9.9hp
YesThanks.
Would you pull the CDI and flywheel from a 1977 9.9 and swap it into a 1976 15 for better spark. I had issues last year with plugs fouling which I suspect is from weak spark. I had to regap and sand the points which was a drag.
