SouthCarolina1
Thread starter- Joined
- Jun 17, 2013
- 169
Alright so I got a steal on a super clean 2002 Sea Ray with a mercruiser 5.0. Oil pan needs replaced see picture! I have pulled engines before. I am thinking raise the engine enough to get under it, replace the pan, do some while you are there's, and then drop it back down. I am looking for some tips for people who have done this before.
List of questions:
Background on engine. Previous life was salt water, its been on fresh water for 3 years and that's where it will be ran going forward. The exhaust manifolds, risers, and boots were replaced 2 years ago. Compression check showed all cylinders at 165 psi +/- 4 psi. Oil pressure at idle was 40psi and increased to 60psi around 2,000 RPMs. When I checked out the motor it was leaking oil but holding it. Then I towed 3hrs home on some crap roads. Didn't have pictures from before towing but now the oil pan wont even hold oil so I think the drive made it worse idk. From everything I can tell its a healthy engine that just needs the oil pan replace.
List of questions:
- Oil pan recommended manufacturer? I vacuum oil out instead of dropping plugs, is there a solid pan without a plug?
- Oil pan gasket replacement recommended manufacturer?
- Just googling I have seen some pans come with rails, are those necessary?
- I am going to clean the bilge, should I paint it? What paint?
- What's the thread pitch of the pan bolt screws? Should I get some black oem ones or SS?
- Starter
- Bilge pump
- Adding a remote oil filter kit
