DoubleD777NE
Thread starter- Joined
- Mar 29, 2016
- 8
This is an evinrude and it’s either a 150 or 175Well----What kind of motor is this on.----2 HP or 300 HP ?----Post some pictures of this motor.
Just acquired the motor and was going to do compression Check. The motor has been in storage for there years so I thought a guy should apply some oil to the cylinders. Are these the high or low compression engines? Thanks.Tis a Big bore 3.625 175 from 1987-91. Looks to have been submerged at one time which wil cause internal damage. Not the best motor as sleeves are thin and if overheated in its life will damage cylinders. It appears someone has applied oil to cylinder due to wetness on water jacket.
How do a guy tell if a low compression kit was installed??? Compression 90 90 90 90 90 88We do not know if a " low compression " kit was installed.------But these motors have a history of broken rings.----Post your compression values.
