Stuntjunkie2007
Thread starter- Joined
- Apr 7, 2022
- 9
Is there anyone on here with experience rebuilding Yamaha 2 strokes?
knowledge - yes. as indicated by @racerone its just parts and piecesI meant with knowledge of actually rebuilding these motors and not somewhere to take it to.
You are the one who is butt hurt. You got free information and are nothing but a spoiled ungrateful 2 yr old. By the way you did have to press it on like Scott said.Scott danforth and Racerone apparently are just no use on this forum. When people ask for help with basic questions I would expect an answer on the question and not to tell me to go buy a press or good luck with my project. I clearly needed to know if it would damage the brass gear by heating it as I have fit gears on shafts in the past with heat but none of them were brass. I did get my engine finished and it runs just fine with no help from both of you. I even built my own press so no need to go spend 170+ dollars on one. Apparently you two are not able to think outside of the box and make stuff. Here are the pictures of how I installed the brass gear. Also If yall get butt hurt and want to boot me from the forums then go ahead. LMAO
You were told to press it on and given a suggestion on a press. You then pressed it on using the advice given here. So by taking the advice you successfully installed the brass gear on the crank. So you not only take up peoples time you are mad about the advice. Then you act like an ungrateful 2 yr old, Good luck with your motor.Flyingscott. What information was truly given other than go and have someone else do it for me or go buy a 170+ dollar press. I could have done without their useless information that was given. My question was would heat mess up the brass gear so it looks like you are the illiterate 2 yr old.
