Reactivity
Thread starter- Joined
- Apr 25, 2022
- 7
So I picked up a Sea swirl Striper 210 WA a few months ago in very sorry condition. Had two POs and one of them had no interest in properly maintaining or modifying it at all. After months of work and a full engine rebuild, the last problem I couldn't figure out was the water pump. I burned up impeller after impeller on the trailer and in the water. I replaced the adapter plate, and did all number of fixes and restorations before finally deciding it was f****d when it worked right and engineering my own solution. I wanted something that was dead to rights reliable and did not require any major modifications to the cooling system. I read a handful of other forums that performed a similar modifications or added pulley mounted pumps but I think I have added some features that improve reliability.
All you need is a 22-28 gpm self priming 12v pump
(I used this one: https://www.jmesales.com/mp-pumps-fmx-75-12v-dc-sp-self-priming-centrifugal-pump-21-gpm/)
A smaller 2-4 gpm self priming pump (I used a normal wash down pump), 3 brass ball valves, some fittings, and some 3/4" tubing.
The total cost ran about 1000 bucks, but it's a hell of a lot cheaper than replacing the ford 302 when it burns up from lack of cooling. For me the peace of mind of never worrying about the cooling system is worth it alone.
I plumbed it up such that the larger ~21 gpm pump is in series with the normal cooling path, inside the engine bay. All you have to do is remove the impeller from the factory pump and reinstall the pump housing with all the seals and everything. Wire your pump up to a fuse and a switch with suitable current passing ability and you are golden. The thermostat will still regulate flow and allow the engine to come up to temp. I also opted to add an additional line from a washdown pump from a different sea chest that connects downstream of the pump, but upstream of the engine. There are 3 ball valves in series that allow you to isolate the engine, the washdown pump, and the main pump separately. I did this for several reasons:
This gives you the ability to prime the main pump if it loses the ability to self prime.
You can backwash the entire cooling system all the way out to the stern drive intake if it becomes fouled.
You can use the washdown pump as an emergency cooling pump to limp home.
The other advantages of this system aside from massively improved reliability are: You can now verify you have full cooling flow before you ever start the engine whereas before if the impeller did not prime you wouldn't know until it was ruined. You can flush the engine without turning it on. You can backwash sea chests easily. You can replace parts that fail at sea since all moving parts of the cooling system are inboard whereas the factory system is completely submerged when at sea. Once setup correctly the system requires virtually no maintenance and will last the life of the boat (no more replacing impellers).
I ran the engine hard and found the cooling performance to be more than adequate. Amazingly even the 4gpm washdown pump had enough flow to easy run the boat up to 7-8 mph (limited by the location of the sea chest. It loses suction on plane because of the mounting location).
The main disadvantage of this system is the electrical demand. If you don't have a 60+ amp alternator I wouldn't recommend doing this. The pump can draw upwards of 15 amps continuously and that is a considerable load on a small alternator. You also need to be mindful of not running the main pump with the engine off as it will drain the battery very quickly. Conversely you need to remember to start the pump within a minute or two of the engine starting. You may also have issues starting your engine if your battery is a bit flat with the main pump running. I'm still developing and perfecting this design, but for me it's miles ahead of the factory "solution".
