Cowl latch is broken : Is there a way another way to repair this in order to keep the cowl on ?
909
I swear these plastic parts are made so cheaply
It came broken off a 9.9 / 15
Is there a way to fix this before I order the part
909
The top half attached to the cowl is essentially a zip tie .
buying the new parts is fixing the cowl.
plastic parts last a maximum of 15 years, that is the nature of plastic parts anywhere near an engine or exposed to UV
909
By design this is prone to failure.
And will likely break again during transport.
Surely there has to be a better solution
Crosbyman
buy an older motor with metal parts
that hurts... but it is funny :)
If new motors were assembled and built the old way , then sticker shock would happen in the showroom.
however low volume plastic parts cost more than low volume metal parts until you get over the 250,000 piece part range once you factor in tooling, etc.
