nola mike
- Joined
- Apr 22, 2009
- 5,969
A few updates from today. New oil switch, rerouted wire harness. Went to put the drive back on, noticed the prop wouldn't turn. Looked in the cavity, decided to remove the prop. Hmmm.
Tried to clean it out and flush the exhaust back and forward. No dice.
Split the drive and found a bit of debris in there.
Cleaned all that out, but the real problem is what I found on the plug when I drained the oil.
This is the drive from my donor boat. I think I put it on last summer some time.
Upper gears and oil looked fine:
So is this drive toast? I'm not into catastrophic failures if I can help it. Anything I can/should do with this?
Anyway, I put on my spare drive. Went to raise it, and click. Up and down. Cleaned connections, no luck. Motor did nothing when I jumped it. I assume the salt bath was not good for yet another component. I pulled the pump but didn't take it apart yet. I found a spare pump, I might throw that in (but I don't know if it works either).
