So I have had more then one issue, but I feel like I'm getting close to 100% with my engine. Ill start off with my dumb mistake I made which was I didn't close the dog house before winter and my cover leaked filling my engine with water. It filled the carb and bent the throttle plates wide open! I had a heck of a time finding replacement plates, ended up buying a junk carb from a marine salvage. Put those plates on my original carb but the boat was smoking a bastard and running rough. So I cleaned out the "junk" carb and put the plates back on that and put that carb on the engine. No more smoke but it still ran rough. I discovered a cracked sparkplug, I just replaced the one plug cause I put all new plugs in last year. But I did check all the others and they were good. Running better but still crappy. Went to check my timing and it was very close, so I decided to dial it in and WACK I got sapped off the cap! So I got a new cap rotor and the sensor in the distributor. BTW this is a TB V system. It runs way better now.....BUT I still have a slight hesitation right off of idle. Sometimes a backfire happens. I hate throwing parts at it till its solved but that seems to be the only way to get this engine to 100%.
So just to recap
New wires about 2 years ago
New plugs 1 year ago (one plug last week)
New Cap, rotor and sensor last week
New fuel filter
Timing checked good
Old ass carb I feel like is suspect might be next to go
I tried adjusting the idle mixture screws but cant seem to make the hesitation go away. (I did this in base timing mode) I can make it worse but not go away.
My other issue and I'm not sure if this is related or not but I cant get over 3600ish rpms at wot. I know this could be prop pitch and stuff but I wanted to get rid of that pesky hesitation before go into changing props. especially cause its a brovo 3 with twin props. $$$
Also if I ease into the throttle it seems ok but if I hit it hard it stutters. accelerator pump seems to be giving a good shot of gas as well right from the start.
before I replace the carb I'm wondering if there is something I should look at closer and does this defiantly sound like a carb issue. (now that I replaced half the ignition system.)
So just to recap
New fuel filter
Timing checked good
