1972 glas_ply need help with power tilt lines
Zaxglassply
neeed a quick run down on the prosses to replace the hy power tilt lines from the pump
dubs283
There is a manifold block on the bottom of the gimbal housing that needs to be removed to replace the lines from the pump. Manifold block is held up by two nuts/studs. Remove the nuts, drop the block down remove old lines and gasket material. Install new gasket and lines, attach manifold block and connect lines to the pump. Keep in mind the lines are up/down specific so label them accordingly
Alumarine
What dubs283 said.
Also, it's best to use a good quality flare nut wrench so you don't strip the fittings.
Might want to tie a line to the old hose, pull the old hose with the line out and then use the line to pull the new hose in place.
Zaxglassply
Right on thanks. What a good repair manual for this boat,motor and trim. It's a 72 glas-ply with the mercruiser 120.
dubs283
Most likely mercruiser #1, possibly #2. Depends on the serial number of the engine
Zaxglassply
whats a good repair manual brand or name. i can order for future things like this lol. 72 glas-ply merc 120 stern-drive' thanks you guys.
achris
More fish than mountain goat
Can only recommend the factory (Merc) manuals. All the others (seloc, clymer, Gregory's) are full of errors and omissions...
Chris...
Zaxglassply
dubs283. i cant run out and look. not at home. this manifold block is the only thing i need to remove or is it after the gimbal is taken off i can get to it. if you dont mine. give me a run down of what to do. thank you man
kenny nunez
Tools needed. 7/16” socket and ratchet, 3/8” flare nut wrench. When you pull the block down you will be able to remove the 2 lines. Just be sure to mark which one is front and rear and to be safe replace them 1 at a time. The gasket may tear and also the aluminum that the block is made from may be eroded away due to galvanic action. There will be grime in the cavity that causes that.
These are what you will need.
Gasket #
MCM # 27-476441 or 27-47644
Sierra# 18-0342
Power trim hoses #
MCM#32-59842 or 32-73005. 32 “
Sierra# 18-2109. 32”
MCM # 32-55816 21”
Sierra# 18-2107. 21”
Zaxglassply
Gasket #
Sierra# 18-0342
Power trim hoses #
MCM # 32-55816 21”
Sierra# 18-2107 21"
Gasket #
Sierra# 18-0342
Power trim hoses #
MCM # 32-55816 21”
Thanks Kenny really appreciate this. Are we aloud to put contact info on here for quicker responses its my first boat and I need a friend lol. Again Thanks man.
Zaxglassply
Gasket #
Sierra# 18-0342
Power trim hoses #
MCM # 32-55816 21”
I just looked at your profile you're down south that's badass. you huntin gators and cool s**t?
kenny nunez
I think I may have hit one with my 24‘ Campbell Daycruiser.
The La. Wildlife and Fisheries just trapped 2 of them in the New Orleans Municipal Yacht Harbor. Any gator under 7’ gets relocated and anything larger gets a bullet. Every so often they are spotted in the local drainage canals. Nutria and Japanese carp keep them happy.
Now get wrenching on your boat.
Zaxglassply
The La. Wildlife and Fisheries just trapped 2 of them in the New Orleans Municipal Yacht Harbor. Any gator under 7’ gets relocated and anything larger gets a bullet. Every so often they are spotted in the local drainage canals. Nutria and Japanese carp.
What is the link to order these parts. See its these lil questions like this be easy just to tex ya hahahhah. are we aloud to put phon numbers on here. Ill send you mine?
