Griff Thomasson
- Joined
- May 24, 2020
- 28
I have a 1993 4.3xl Mercruiser in a 2050 Chaprell , boat runs great how ever pulling throttle back in no wake zones over heating alarm goes off . Open her up and she cools down ...
I replaced 160 deg thermostat last season to a 140 and no difference ... drilled 3 -1/4 inch holes in thermostat
I have cooling system torn down completely , New impeller in out drive ( new out drive ) While out drive was off boat I back washed hose from out drive checking for clogs in power steering cooler ...
Risers are fine ---one manifold is new , other found a hair line crack outside .. replacing that one ...
I pulled water pump off and will replace it with a Mercruiser pump... with pump off using a hose I flushed each side of the block with drain plugs remover , using a pick in circles and got out rust scale maybe 1-2 table spoons from each side , cant fill each side up with water now ...
I suspect this may have been part of the problem !!!!
I found a quarter sized piece of scale on hose going from pump thermostat housing ?
May have been part of the problem ???
Any suggestion on cleaning the block out ???
I am 72 owned boats all my life
OH I checked to make sure no spark plug wires were in correct order they are correct
Boat in fresh water as long as I have had it !
