Help me place garmin transducer
Kmpcfp
Where to mount a Garmin transducer (with Striker 4cv) on my Tahoe boat? I can't figure out where to place it so there will be minimal interference. 20220517_141922.jpg
to the right of the outdrive, per the garmin installation manual which will be about just above the one bunk and hit your trailer tie down strap
Kmpcfp
Thanks. You mean the spot I marked in blue, correct? I have seen others put it at the red spot as well, so I wasn't sure.20220518_141004.jpg
dingbat
Hard to say w/o seeing the underside of the boat at both locations.
Suspect either location would suffice
blue will get the cleanest water. however as the manual states, you have to verify clearance with the motor, etc.
