Lost power on return to ramp screws missing from transfer port caps. 94 force 120
wildvortex
Upon returning to the ramp my engine power reduced drastically. As long as I kept the throttle high the engine would run. Fortunately, I was able to make it back to the ramp.
When I got home I took a quick look and there was oil everywhere on the right of the engine when looking from the back. I then noticed one of the transfer ports was missing some screws and the gasket was non-existent.
First will I likely just need to get the new gasket and find the screws put it all back together and everything be fine? If so, what is a good source for the gaskets for the force 120?
TIA,
Steve
jimmbo
You could make a gasket.----Take one of the bolts ( 1/4-20NC ) to a hardware store and get some new ones.
wildvortex
Thanks Jimmbo, when I went to their parts breakdown for the block it showed the gasket but when I went to the number in the parts list 43 (I think) it skipped over it.
wildvortex
I believe I can find the bolts in the bottom of the case. If not that was my plan to get new. That was the simple part.
As for making a gasket I had also considered doing that. Even better for me I have a laser cutter/engraver would just need to draw the gasket in CAD.
But, if I can find it at a decent cost I would prefer the correct part and thickness. Might have found 3 last night. Iboats only has one. Crowley shows having them in stock for $5.70 each.
wildvortex
Problem is now solved.
Yah sort of, one question not answered. Could anything else have been damaged by the lost bolts/blown gasket.
I am not so sure what the transfer ports purpose is. I am assuming it is fuel related and if so could some of that gasket material been sucked into the cylinder?
jerryjerry05
Try ebay for gaskets?
The port cove is used for inspection.
Take it off and you can see into the rings and piston cavity.
jerryjerry05
I have a snake camera that I use to check for damages in places like this.
Camera, ebay 11$
wildvortex
Oh, and even though I put in the correct part number in my search Crowley.
Thanks Jerry. So, some of that gasket could have been sucked into the cylinder?
wildvortex
Camera, ebay 11$
Yah, I have a couple, good idea. Need to get the electronics plate off and have a look into it. Unfortunately, the gaskets I pulled up on Crowley were a different part number and for a different year. Not positive they will fit. Tried a second search and found the correct part number for $16. The two options I found on eBay have become the better option.
wildvortex
Well more research and found a good diagram of the purpose of the transfer ports.
Thanks all,
Guess problem solved now. ;-)
wildvortex
One last question. It appears to be sold in packs of two. Are these gaskets doubled on each of the transfer ports?
One gasket.-----Do you understand that your motor is a 2 stage air processing machine ?-----Air / fuel is pulled into the crankcase when piston goes towards sparkplug.------That air is compressed in the crankcase when piston moves away from sparkplug.-----That fresh air / fuel rushes into the cylinder when intake ports open.-----You lost crankcase compression when gasket failed.
wildvortex
Yes, I had figured out how the transfer ports work. I was just stumped when I was told that the transfer reports were for inspection. Figure they had to have more purpose than that.
Just wondering why sold in packs of 2 when the engine needs 3 total and Crowley shows 3 of that part needed when ordering. In fact, when I hit add to cart it automatically adds 3 packs of 2.
Many shops have DEMANDED that the factory stops selling / providing parts in quantities of ----ONE-----Too much shop time is wasted !!-----That is why parts are now sold in kits and it saves everybody some beer tokens.-----So that package should have 5 gaskets to cover the 2 , 3 , 4 and 5 cylinder motors !
wildvortex
Would make sense but am putting in a 120 which is a 4 cylinder and states 2 gaskets. Guess I just need to order 2 packs. Have to go to the hardware store for some other projects so might just try cutting them myself with the laser.
Thanks for your help!
When I look up the 94 model 120 HP it says-=---3 gaskets required per assembly.------The people that write parts manuals may not be trained mechanics !!
wildvortex
So true. Likely will call Crowley although they may not know either. In any case headed to the hardware store for gasket material and odds and ends. Screws likely can be recovered. But working other needed project so won't know until I dig into it further
