DeepCMark58A
- Joined
- Aug 17, 2015
- 3,489
Can I use anti seize instead of grease on the prop shaft?
I also make sure to clean the threads with starting fluid and a rag. Or wirewheel if you can get to it. Get all the old corrosion off etc.Thank you just wanted to check, never know if there is some crazy reason not to.
It will be fine. I have been using it in salt water for years and never had an issue getting the impellers off later.Well at this point I will report if there is an issue in the fall, it's on. I have to get the boat in the water my son is coming up tomorrow and he wants to fire up the boat for a few runs down the lake. Unfortunately I will not be here for that 6:15 sunday morning flight.
