4.3L MPI 2007 Searay Sport 185. Single Alarm at 20 RPMs and higher
Status
Not open for further replies.
Nord2903
Find a new mechanic. With the alarm going off that means there is an active fault and should be present with a scan tool. Either he doesn't know how to use the scanner or it's not the proper scan tool.
One time I had a mercruiser that would randomly shut off, then beep. No active faults when it happened and no stored faults. Came to find out the motor had been removed for a coupler and when reinstalled the main ground for the harness/ecm was on the opposite stud from the main battery ground. Got the grounds stacked together on the same stud and issue went away.
After tomorrow, thats going to be the case cause he is calling it quits and can't figure it out. Talked to my buddy who said it could be the ignition control valve. Problem is that im 14 hours into work at 125/hour and no solution. I almost want to ask him to check it but if its that im getting charged the full price with providing my own solution that I failed to check
Status
