Deck Leak
Donnnn
I have a 1997 1830 ss that has just developed some sort of leak with water coming from under the bow deck onto the main deck soaking the carpeting. So the leak is from high up, not down in the hull. I also found water in the forward bow locker - the one with the drain. Can you please help me try to identify what is causing this and how to fix it??
Donnnn
I discovered that the hose from front cooler locker to hull fitting was broken. Instead of contorting myself into those small spaces, I just silicone sealed both the inner and outer fittings since I never use that cooler locker anyway.
