2000 Johnson 25hp 3cylinder. Help
Ronniewhite
I lost the sticker with my model number. It's a 2000 Johnson 25hp 3cylinder long shaft. No steering wheel. Electric and pull start. The sticker below the one I lost says it's a 2000 and the engine family number is Y1PXM0034210. Thx in advance
And what help are you looking for.-----They are heavy so do you need help lifting it ??
Ronniewhite
I was wondering if anyone new the number I lost. I need to order parts but there's a whole list of numbers for a 2000 25hp 3cylinder Johnson.
Most parts were the same for all the production years.-------So what parts are you looking for?----In Canada----evinrudeparts.ca----will help you.
If the oil injection is still in service it should be taken off.-----Heaved away over the fence as far as you can.----Mix at 50:1 in the tank.
Ronniewhite
No oil injections. I do have a problem with it tho. I thought it might have been a coil but it's not. I checked them with adjustable spark gap tester. Once it's been running for a half hour or so just when the throttle is turned right down it makes a poof and a puff of smoke about every 30 seconds. If it's running with the throttle turned up just the slightest it won't do it.
Ronniewhite
Hey I was wondering if you can help me out again. I'm trying to change the impeller because the motor over heated at idle. If I turn the throttle up it cools right off. I changed the thermostat. I got the nut separated behind the finns. I have the six bolts out, 3 on each side. I can pull the lower unit off. It slides down about a foot then stops and I can't get it any further. What am I missing?
