Evinrude 115 hp 1987 how to replace pressure relief screw 0 Ring gasket
LOCK N LOAD
How to replace the 0 seal on the screw. Any help would be greatly appreciated.
I assume you mean the manual release for power trim / tilt.----You remove circlip ( installed at the factory ) and remove the screw.------Replace o-ring.-----Install screw.-----Install circlip.
LOCK N LOAD
Yes sir!
A friend just got this motor and it's leaking. We noticed the 0 ring had partially fell out. Was wounder how to replace it. Does he need to remove the motor to access the circlip? Thanks again!
