FLATHEAD
- Joined
- Dec 29, 2002
- 3,940
2003 BF15 started it on the muffs yesterday had a decent stream for about 30 seconds then nothing. Got to it this morning , what I’ve done so far. Ran a wire in the tell tale, no change. Pulled the lower and inspected the impeller, is like new cleaned everything up, ran a wire in the tube running up to the motor, seems clear put lower back on, no change, still no water. Pulled thermostat cover, dry as the desert. I’m assuming no water is getting to the motor at all. I don’t have a drill at home with big enough chuck to put on the shaft to run pump alone in a bucket. I have tried the motor with both muffs and submerged. What’s next? Any help would be appreciated. Not a lot of experience on outboard motors.
