Mrproffitt
Thread starter- Joined
- May 8, 2022
- 17
Hello, I’m having an issue with the boat dyeing after about 40 mins of use. Can not duplicate the issue on muffs. I’m the second owner of this boat and it’s new to me, the previous owner was chasing this same issue. It acts like the key is cut off while on plane at 3000 rpms, drops to an idle and will not take any throttle like it’s out of fuel. I am certain it’s not a fuel issue.
The boat is a 1996 Bayliner Capri 2050 with the 5.7 Mercruiser with two barrel carb. Here’s a list of things done to the boat in the last month.
New fuel system, marine pump, hoses, bulb, carb rebuilt, tank drained and checked for obstructions, dip tube checked, new filters, checked tank vent, new EST distributor, new ignition switch, new alternator, new battery, new starter, checked all grounds, new heads and all gaskets, checked shift interrupter, checked cannon plug at engine for corrosion. All this has been done chasing this issue.
I’m about out of options on this one. The only thing I can think of is something is getting hot and failing after about 40 mins. I’m thinking that the tach might be the issue grounding out, but it seems to be working fine, or possibly the master circuit breaker. I don’t know if I’m losing power at the distributor when this happens. But it’s next on the list this weekend.
The issue is persistent, and like clockwork every time we’ve taken it out. The engine runs like a champ for about 40 mins, then cuts out. I’ve chased everything in the manuals I can find to this point. Are there any hidden relays that I’m not aware of. Thanks for any ideas on where to look.
