DeepCMark58A
Thread starter- Joined
- Aug 17, 2015
- 3,544
Had an issue last fall with the motor losing power than not running. The boat has a built in tank so I replaced the fuel filter, the fuel pump and fuel filter. The motor would not start. I suspected an issue with the fuel pick up so I went and bought a 6 gallon can and plumbed that in the motor starts and runs. I put the boat in the water and the cold start is better, the low idle is better. When I put the boat the to full throttle it not not stumble at all it is running about 1500 rpm lower than what it ran in the past. Not sure what the issue is.
