ggundersen3
Thread starter- Joined
- Dec 25, 2007
- 249
Water in bilge was solved last summer with replacement of the water pump in the lower unit by a reliable local marine dealer. No more water appeared in the bilge, Now this summer I'm now getting about a 1 to 1-1/2 gallon of water finding its way into the bilge after about 3-4 hours on the lake. 2 questions here.
1- Would it be smart to put the boat on the trailer and with the drain plug in and bilge pump shut off, put the garden hose directly in bilge, let a few gallons of water gather and see if water drips, or seeps out anywhere indicating a leak?
2- The boat has an original equipment depth finder, I can see the through the hull transducer in bottom of the engine compartment. I can also see it on the exterior/bottom underside of the hull.(see attached pic) Is that ever known to eventually leak? Could that be how water is getting in bilge?
I greatly appreciate advice/help/opinions.
Thanks
Thanks
