Hello
I've had this outboard since new and it's never really given my any problem until the past year when it started to quit at idle. It would start ok and once warmed up when I'd bring the fast-idle (or whatever that's called) down it would idle for a minute or two and then quit. Restart would be ok but basically as soon as it was moved back to idle it would likely quit (not always but mostly)
Once moving it would be fine and to top speed was the same as always, sounds fine, etc etc etc but I slowed down to idle, say pulling into a dock, it would most likely quit.
I took it to a local mechanic who was recommended for outboards to do a "tune-up" and once over, he called and said the compression was too low and that was preventing the fuel from being pumped (delivered) at idle and it wasn't likely worth rebuilding rings, bearing, etc.
When I picked to boat back up he said the compression was pretty even but 110 pounds.
ANYWAY, looking for any suggestions for a way to limp through the season somehow and was wondering if there was a way of bumping the idle rpm a little bit but still letting it be shifted out of neutral or well pretty much any input at all.
Thanks
Thanks
