Hi all, i rebuilt my Mercarb over the winter and and also had the distributer out of the engine. So this spring I reinstalled the carb and adjusted the timing and got the engine running. Problem is, I cannot get the idle down. I start the carb idle adjust screw at 2 turns in on the cam and the mixture screw 1 1/4 turns out. The engine runs fine at 1000+ rpm, but no amount of adjusting gets the idle down to the required 600-700 rpm. I'm going to check the fuel pressure, as the pump was changed, but other than that what issues in the carb could cause me not to get the idle down? I've verified float level and drop, the jets are new, etc. Really not sure what to try next.......
Thanks!
Thanks!
