lrdchaos
- Joined
- Feb 11, 2008
- 265
Going to swap out me gear lube on my b3 outdrive.
So I’m going to take off the cap on the reservoir on the engine, pull the vent(upper) plug, pull the lower plug and make sure the drive is down.
Once it all drains, I will start pumping 90w high performance gear lube from the bottom hole until it runs out of the upper hole on the drive, put the plug back in and keep pumping until it backfills the reservoir. Once the reservoir is full, unscrew the pump tube and replace the bottom screw.
Did I miss anything? I also plan on replacing the plug gaskets.
