Trouble with my '09 5.0 TKS (Carb) #1A342087. Engine died on the way back to the slip and will not restart. If I jump the fuel pump straight to the battery, it will run. I believe my issue is in the Purple/Yellow circuit that feeds the fuel pump via the oil pressure sensor. I have also just replaced the oil pressure sensor 2 days ago as the 1st known culprit for this issue. Anyone have any thoughts on this? Its a carb motor so it's pretty simple but I'm at a loss. Only thought I have is the starter solenoid could be bad because I do not have any power on the P/Y wire at the solenoid in any condition. I have been told by several people, these units 'never fail' but I keep thinking I'm the lucky one.
Edit: If I get it started when cold, it will run for no more than 5 minutes sort of until the engine warms up and then dies. I'm assuming its just burning up all the fuel in the carb.
