Snaspen101
Thread starter- Joined
- May 14, 2022
- 28
I have a 1989 four winns vista 245. It has the 7.5l 460 with cobra outdrive. My issue is I have water leaking from rear of motor. I can't tell from where. I have good flow from impeller through the lines. Both exhaust manifolds drains ate closed. Am I missing a drain or is there something else that could cause this? From what I can see, I have no leak from from inlet hose around the the block. It seems to be coming from rear of motor. I might add it flows at a good rate as well. It's leading me to believe there is another valve I'm missing. (Raw water cooled).
