presleymarkw
Thread starter- Joined
- Jun 14, 2021
- 43
So I replaced Impeller. Not as hard as I expected. Definitely had damager but should have been pushing water. Replaced caps and gaskets and impeller. Still no water flow.
So I assumed thermostat but after removing intake manifold I see that water should always be passing through. I'm not clear on how the thermostat works. I don't see any connection between the water passage in the intake manifold and the thermostat passage. From what I have read when the thermostat opens water is directed through the engine, but it should always be peeing.
There was no obstruction in the pee passage. It was dirty but water could flow. I realize now I should have connected the water hose first that goes into the intake manifold and check water at this point and I may not have need to open the intake.
I will have to get a new gasket to put the manifold back on to check the water passage before going into the intake manifold.
Assuming that hose is clear, why I am not seeing water? The thermostat open or closed should not stop the engine from peeing.
Thanks for any help and suggestions.
