Rick Stephens
- Joined
- Aug 13, 2013
- 6,118
Wow, that's ugly.
they come loose. Last summer my neighbor was loosing PS fluid into the bilge return line off cooler had a loose clamp. when i went over the engine almost all the clamps on the cooling hoses were dangerously loose.Alright, found my problem! I love stupid easy stuff. Interesting that I ran it like this all last season without noticing; it must have been like this since I installed the engine.
Also after yesterday finally installed a new (bigger) bilge pump and rewired most of my boat lift.
I'm guessing you're working with 240V and 10 amps. I'd go for an industrial style disconnect switch that's NEMA 4 rated.I'm still trying to find a dpst rotary switch to use as a safety cut off, if anyone knows where to get one lmk. I can find rocker switches but they seem easier to flip accidentally
Nope, 2 dc motors switched by relays. I want dpst so that I can switch both circuits at the same time. Amperage through the circuits is minimal, only enough to switch the relaysI'm guessing you're working with 240V and 10 amps. I'd go for an industrial style disconnect switch that's NEMA 4 rated.
Visit an electrical supply house, a lot of these switches and contacts are customizable and mix and match, they can help you configure exactly what you need.
Here's an example:
https://www.gordonelectricsupply.co...truding-Black-Handle-Single-22Mm-Hole/6128735
https://www.gordonelectricsupply.com/p/Square-D-Vls3P016D1-3-Pole-16A-Ul508-D-S-Door-Mount/6128775
Smart womanMy wife was very adamant that any boat repair made with "duct tape of the sea" was not something that she would consider sea worthy.
Our friends think her taste in men is suspect.Smart woman
Youve come a long way with this , most other folks would have left it rotting in the yard…keep going…Just when I think I can let this thread die...
Good news: Boat doesn't seem to be leaking anymore. Going to remove the marine adhesive and just plug with marine tex. Not sure why I thought that I wanted to screw around with poly resin.
Bad news: More electrical gremlins. Made it about 6 miles off shore today before I had the sickening engine cut off boat dead in the water feeling with a stout wind blowing me off shore. This time my fuel pump relay was toast. My 11 year old asked me some questions about electricity, and told me that he had learned about electromagnets in school. Took the opportunity to cut open my relay and show him the electromagnet and how the relay (didn't) work. So that was actually fun. We also had packed some beers and snacks, so just dropped anchor and chilled for a bit. Jumped the pump off the battery and made it home. I think I have literally cleaned/replaced every electrical connection/device in the boat at this point. Only mission critical thing I can think of is the ignition components; if something fails there it's un-mcguyverable. Wondering if I need to worry about that at this point? Do I buy a backup TB 4 module and sensor? Sucks that I did this swap partly in the name of reliability...
Also discovered that if I move the boat too far forward on the lift, the bunks will rip my depth finder transducer out of the hull.
Yeah, at this point it's personal. If I had any sense I would have cashed in my chips on a boat that I bought for 4k 13 years ago. This same attitude unfortunately applies to every aspect of my life, which is why I'm always stressed about getting things done. Wondering if it would be worth upgrading to tb5 and keeping the 4 as a spare. The tb5 seems a lot harder to find though. I did replace my corroded horn button with a pretty jazzy led lit button (horn is a mechanical air horn that plays la cucuaracha). It's a crowd pleaser. I'm hoping I can do something "fun" next--my whole stereo system is of course toast as well. I have a spare head unit and amp that's waiting to go in, although I guess I need to see if the speakers are dead as well. Between this and my vegetable garden I've put in 6 figures worth of time this year. I also have a 3hp outboard that hasn't been run in 20 plus years that I've been planning to keep on board as a kicker... Another project. Although I checked the gear oil today as well, no water, so at least that's encouraging.Youve come a long way with this , most other folks would have left it rotting in the yard…keep going…
i would carry an extra fuel pump relay and i do keep a tb module and distributor sensor on my boat. I got a used module off ebay for like $200, had a spare distributor off my old engine. also keep a spare set of plugs cap and rotor fuses some crimp wire connectors length of wire spare drive belt.
I have a big plastic tub with my tools and spares engine oil, gear oil, spare prop hub and fittings.… maybe over prepared but i have had to change a prop floating in a life jacket in middle of the lake, just gotta make sure not to drop the thrust washer….
